This question is probably for Gary Ramadei..... What is a source for the special shims used between the sector shaft and adjuster screw on a C2 steering box ? Also, what is the correct clearance & what are the symptoms of a problem in this area? I see shims listed as part of a rebuild kit, but, not as an individual item.
I finally installed a rebuilt box I've had for years & believe I have the "high point" marks lined up per the manual . However, I did not do a "bench adjustment" ( my inch/lb torque wrench STARTS at 20 ). I don't remember any shims on the adjustment screw. Yeah, your first question is how I saw that part of the adjustment screw on a rebuilt & adjusted box?? Well, I had previously removed the cast iron cover to replace my incorrect aluminum part instead of changing out the box....
...obviously destroying the adjustment . So,it may, or may not, need a shim.
THANKS for any help!
...obviously destroying the adjustment . So,it may, or may not, need a shim.THANKS for any help!
