Re: 396 Hot Start Issues
Hard crank is usually a timing issue, too much initial timing. One fix is to recurve distributor or a high torque starter. On an old TI amp the original circuit board used germanium transistors, which crap out above 230 degrees.The new board use silicon which is good to 300 + degrees. When the old board cools down it'll start right up. That also affects the timing.
