C2 Fuel Injector inspection tag codes - NCRS Discussion Boards
  • Justin W.
    • May 31, 2006
    • 16
  • Leif A.
    • August 31, 1997
    • 3607
    Re: C2 Fuel Injector inspection tag codes
    Justin,
    Did you forget this information?
    The top set of numbers is the 1963 part number, 7017375. Below that in the four boxes is: C/A63/04/04
    Just trying to help with the process.
    Leif
    Leif
    • Justin W.
      • May 31, 2006
      • 16
      Thank you Leif
      • Dan H.
        • July 31, 1977
        • 1365
        Justin, Brian Futo wrote an article in the Restorer about the tags, Spring of 82. You can get the articles from NCRS store on CDs etc.
        Dan
        1964 Red FI Coupe, DUNTOV '09
        • Bob J.
          • December 1, 1977
          • 713
          7017375 = RP unit ID
          C = third revision for 7017375 was installed
          A63 = January 63 date RP built the unit
          04/04 = inspector stamps
          By having the 04/04 on the tag it means the revisions were factory installed, not field installed, since field installations had no inspector.
          This is all assuming the tag is an original.
          I did a little digging, through some tags I have, and your tag doesn't seem to line up with RP installed tags I own.
          My C3 original tag is only at revision B, which is the same as my D3 revision kit tag.
          My A3 tag has no revisions. I'm a bit skeptical that a January unit would be installed at RP with the C revision.
          • Dan H.
            • July 31, 1977
            • 1365
            Hi Bob, does anyone have a break down of what was done for the revision codes for the 375 and the 380 units?
            • Bob J.
              • December 1, 1977
              • 713
              Hi Dan,
              on a 380 unit I'd give John Degregory a call when he returns from Carlisle.
              Bob J
              • John D.
                • December 1, 1979
                • 5507
                The info on the tags is not an exact science. Many variations on what was put on those inspections tags.
                For Example: The first box is typically A or B or C. But not always. Sometimes the first box can contain a two digit number. Refer to Ken Kaysers book on that.
                The 3rd and 4th boxs also have variations. I have seen inspector numbers rangine from 1 to 8 written like 01/01. Most of the times I see these numbers on a severe angle.
                As Dan said refer to Brian Futo's old article on the tags. I think there may have been one more article throughout the years in the Restorer but I could be wrong.
                The first tags used on the '4360 and tghe '4520 had inspector punch holes in them. Very rare. John
                Dan, I can't answer your question. Don't know the answer.
                • Justin W.
                  • May 31, 2006
                  • 16
                  Bob, thank you. Unfortunately I'm not too surprised by your comment. That A3 tag with no revisions, are there only 3 codes/boxes? Here's a photo of the tag on my FI unit, no angle on the inspection stamps either. What's your impression?
                  • Bob J.
                    • December 1, 1977
                    • 713
                    Justin,
                    in my opinion its not what I'm use to seeing on original cars.
                    Regarding JD's comment on the first box containing anything other than a single letter or blank space,
                    I've not seen one original example of double letters, on any 7017375 unit, in that past 40 years.
                    Bob J
                    • Justin W.
                      • May 31, 2006
                      • 16
                      Bob, again not surprising, just disappointing. But that's OK. In going through my restoration there were enough questions about the authenticity of this 63 being an original L84 (as represented to me years ago) that we're rebuilding it as a L76 with a FI conversion. I wasn't planning onmasqueradingthe car as an original L84.Thanks for you help and expertise.
                      • Bob J.
                        • December 1, 1977
                        • 713
                        Justin, this is an original RP C3 tag for comparison. Bob J
                        • Justin W.
                          • May 31, 2006
                          • 16
                          Bob, thank you. Quite a difference. If I only knew then what I know now. Or that I had sought out the right assistance at the time.....
                          • Bob J.
                            • December 1, 1977
                            • 713
                            Justin, you are quite welcome.
                            Write me if you need 63 advice going forward.
                            Bob J
                            • John D.
                              • December 1, 1979
                              • 5507
                              Bob, Sorry I mislead you fellows. I was making a general statement on the tags. I have never seen a 7375 with double "numbers" on it in the first square.
                              But I did see a 7014960 tag that way. It's in Ken Kaysers book and I saw one here at the shop.
                              Justin, Do you feel your tag is an original one? It just may be an old repro.
