I have an L 11 2 (Dec 11, 1962) block needing heads and found a set dated K 17 2 (Nov 17, 1962) Would they be judged/considered correct? Car is a 300hp powerglide.
Head "K 17 2" correct for block "L 11 2"??
Tags: None
Re: Head "K 17 2" correct for block "L 11 2"??
Dates on heads are not judged but they sound good to me.- Top
Was the (I) used for castings like cylinder heads and engine blocks, I can't remember.- Top
From the CAMARO RESEARCH GROUP:
EdFor cast-in date codes on GM-produced iron and aluminum castings (engine blocks, heads, intakes, water pumps, etc.), the letter "I" was used for September, and the last month of the calendar year (December) was the letter "L". For stamped-in date codes on GM-produced components (alternators, distributors, starters, etc.), the letter "I" was not used - "I" was skipped, and "J" became September, with December being "M".- Top
It sounds like I should snag these heads. About 30 days apart doesn't appear too exaggerated to most who've chimed in.- Top
