1970 lt1 - NCRS Discussion Boards
1970 lt1
  • James S.
    • August 21, 2013
    • 53
    1970 lt1
    My 70 LT1 had headers on it when purchased by previous owner,what heat riser do i need to look for to make it right? and who sells the best welded exhaust sytem for a 70 LT1? Thanks for any info....
  • Mike F.
    • April 25, 2011
    • 668
    Re: 1970 lt1
    IIRC the heat riser valve is just the standard 2" valve used on all small block Corvette's from 68-74.
    I believe most people go with either Gardner or Allen exhausts, but you will need to get the mufflers welded to the exhaust pipes on your own.
    http://www.gardnerexhaust.com/ or http://www.allencorvetteexhaustsystems.com/
    • James S.
      • August 21, 2013
      • 53
      Re: 1970 lt1
      Thank you.
        • 43193
        Re: 1970 lt1
        James------
        The original heat riser was a GM #3887024. That was discontinued many years ago and replaced by GM #362652 which is now also discontinued without supercession.
        The 3887024 would be the most correct but it might be difficult or expensive to find. Also, be aware that many of the valves on the market which claim to be "NOS" are actually aftermarket valves which REPLACE the 3887024.
        Most of the valves on the market are reasonably similar to the original valve, though.
        • Bill L.
          • February 1, 2004
          • 1403
          Re: 1970 lt1
          IMHO the Gardner system is still not correct and very very expensive. There are previous threads discussing exhaust systems. The Corvette Central system fits great and costs a LOT less. They also offer free shipping on occasion.
          Gardner's material and bends may be more accurate but the system is not welded. Corvette Central's system is aluminized and while bends and and material are not correct the system is welded.
          If Garner's system was welded correctly I might have spent the extra but at this point neither one is TFP.
          Bill
          • Leo M.
            • May 31, 1995
            • 35
            Re: 1970 lt1
            You can order a carbon steel system from Corvette Central. Takes a couple weeks longer. I have purchased several complete systems from Corvette Central and they fit great.
            • Michael F.
              • 745
              Re: 1970 lt1
              why not go to a local muffler shop and have them copy the original?
              Michael
              70 Mulsanne Blue LT-1
              03 Electron Blue Z06
                • 11608
                Re: 1970 lt1
                Not much point in this (no pun intended), as the difference in point deductions between a CC carbon steel system and an aluminized system is only 1-2 points, and the carbon steel will rust. I've installed the CC systems on several cars with good results.
                  • 43193
                  Re: 1970 lt1
                  Michael-----
                  I doubt that any muffler shop on earth could copy from scratch any Corvette exhaust system.
                  • James S.
                    • August 21, 2013
                    • 53
                    Re: 1970 lt1
                    i wound not trust any muffler shop in my area...lol
                    • James S.
                      • August 21, 2013
                      • 53
                      Re: 1970 lt1
                      thanks ive looked at paragons and corvette central and the corvette central system looks better and im going with the aluminum coating
