'67 Power windows work with the key off - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    I am chasing a battery drain and this may be related or another problem.
    The power windows work with the ignition off and key removed. What could cause this??
  • Larry B.
    • October 21, 2010
    • 254
    Re: '67 Power windows work with the key off
    Where would I start checking? Could it be the ignition switch or power window circuit?
    • Don H.
      • December 1, 1981
      • 1482
      I'm not sure about '67 but I think earlier mid-year power windows worked with the key off (any time). Don H.
      • Domenic T.
        • January 29, 2010
        • 2452
        Larry,
        It took a few children to die due to working the windows with the key off and getting strangled for the manufacturers to finally put the windows on the key circuit. Kids would put heads out the window and the live switch would strangle them.
        Sorry about the gore but that's what it took.
        DOM
        • Larry B.
          • October 21, 2010
          • 254
          Hi Dom, So the '67 windows worked without the key or did they change in '67?
          • John C.
            • January 1, 2005
            • 616
            Larry
            For 1967 your power windows should only work with the key in the ON, or Accessory position.
            John
            • Larry B.
              • October 21, 2010
              • 254
              Ok John, Seem to have conflicting opinions on whether they should work with the key off and out. What could the issue be then causing them to stay on?
              • John C.
                • January 1, 2005
                • 616
                Larry
                Is your wiring harness connector for the power windows plugged into the correct position on the fuse panel. It should be plugged into the receptacle marked - ACC. FUSED. This is shown in the AIM in section A31 page A1.
                John
