Does anyone have experience removing the "welded on" remnants of factory making tape glue on the rear window? I have a NOS rear window with multiple spots of old glue and am unsure how to remove it without using any type of abrasive. So far rubbing alcohol, naphtha, goo-gone, baby oil, denatured alcohol and mineral spirits have been applied. A few small spots were removed, but there are more that won't budge. I'm afraid to put anything stronger on for fear of softening the plexi or later crazing.
40 year old tape on Hardtop Plexiglas
Re: 40 year old tape on Hardtop Plexiglas
You might try 3M adhesive remover. That stuff works when others won't........ It doesn't affect paint so it may work on Plexiglas......- Top
I just tried LPS PreSolve orange degreaser and it seem to be doing the trick. Saturated a small piece of cloth with it and let it cover the glue for a few minutes. Very gently rubbed the glue and a lot of it came off. A few more applications should do it.- Top
Stu
I use plain old Pledge Spray Wax on my motorcycle Plexiglas windshield. A motorcycle forum similar to this put me on to it. It could not take out a couple of old deep gouges but it sure cleaned up most of the windshield nicely. Now it is an '82 Honda so I was not too concerned with it having any ill affect on the plexi when I first tried it so do so at your own risk.
NormGolf is for those who can't play hockey.- Top
Lemon juice may work on "fresh" sticky labels, but is useless on old, hardened glue. LPS Orange degreaser applied to a small, clean piece of cloth and let to stand overnight did the trick. A q-tip soaked in LPS and rubbed over the area afterwards removed the almost all of the glue.- Top
