'67 Charging System Test Needed - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    Replaced the battery, VR and found bad diodes in the alternator. Stock 327. Had the original alternator rebuilt. The car is still not charging. Is therea test to isolate the voltage regulator or alternator as the culprit. Does someone have a test to isolate the problem. Thanks
  • Donald O.
    • May 31, 1990
    • 1580
    Re: '67 Charging System Test Needed
    Larry,
    How do you know it isn't charging? You will definitely need a DVM (Digital Volt Meter) to know the battery voltage, before cranking the engine to start and what the voltage is after starting and revving it up past 1500 for a few seconds. A test light will not be sufficient.
    DonO
    • John D.
      • June 30, 1991
      • 874
      • Larry B.
        • October 21, 2010
        • 254
        Thanks. With a voltmeter, I am running off the battery right now.
