On my 64 FI car, took it for a test drive today after replacing radiator, water pump and fuel pump. I opened it up (90 mph) and, when I let off the gas, it kept going at over 6500 rpm. Had to cut the ignition with a huge backfire and rolled to a stop. Under the hood jiggled the bell crank and it released. Had the same issue a while later and cut the switch immediately. This time I tried to jiggle the acclerator rod inside....no result. Again, under the good, moving the bell crank released the throttle (when the return spring would not). I've done no analysis yet but think a little knowledge if better than hunting and pecking.
I'm wondering about the throttle plate/shaft in the air meter. This seems like a pure mechanical issue as the bell crank was definitely stuck in an open position. What would you look for?
