62 fuel pump - NCRS Discussion Boards
62 fuel pump
  • Roger B.
    • June 30, 1991
    • 82
    62 fuel pump
    I have a tube from fuel pump to afb carb which seems to be to long to connect into the carb.this is from corvette centralis it the wrong tube?to connect it i have to raise the carb 1/2 inch?thanks
  • Greg S.
    • July 31, 1995
    • 243
    Re: 62 fuel pump
    Make sure you have it oriented correctly. Even though you wouldn't think so, it will fit with some bending if you have the pump end at the carb end. Ask me how I know. Once I turned it around everything fit as it should. I got mine from CC also so I know that they will fit OK assuming everything is set up as original.
