Garage heating options
Re: Garage heating options
I added this to my garage.
10,000 watt
heats up the entire garage perfectly
has an adjustable thermostat.
I can work in shorts and a t shirt during Chicago winters.
http://www.northerntool.com/shop/too...6377_2003163771954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
Cooling and removing humidity from a garage can be a double edged sword. Yesterday I backed my C5 out the nicely cooled low humidity 72 degree garage into the high humidity 90 degree outdoors and had condensation form over the entire car. I had to turn on the wipers just to see out the windshield.
Mike- Top
Mitsubishi is the only brand I sell. Recently they've begun offering a high efficiency unit that is rated to produce 100% of it's rated capacity down to 5* (of course you'll have to remove the snow from around it or use baffles to prevent build up) and has a SEER rating of 30. In my opinion they can't be beat in terms of quality and performance.- Top
That's really impressive. I've always heard heat pump efficiency drops significantly below 40 degrees. Which in Indiana is about 1/4 of the year.Mitsubishi is the only brand I sell. Recently they've begun offering a high efficiency unit that is rated to produce 100% of it's rated capacity down to 5* (of course you'll have to remove the snow from around it or use baffles to prevent build up) and has a SEER rating of 30. In my opinion they can't be beat in terms of quality and performance.
Mike- Top
I also thought heat pumps were not good in colder temps. if your garage is attached to your house. i have a renzor unit which is hung on my ceiling and i added it as another zone to my house heating which is hot water. the good thing is that your epoxy floor seals the concrete and blocks out almost all the dust i to have an epoxy floor and my garage is almost dust free. this unit keeps my garage so warm i work in shorts and a tee shirt when its 10 degrees out i highly recommend this system and think it will be a great choice for the chicago area.- Top
I know a few people that have these units and love them. I have radiant heat in the concrete floor - no a/c but I do have a fresh air handler (never get a compalint from my wife even though the garage is directly beneath the kitchen.) in my working garage I have a unit similar to John Hinckley'sDan Young
65, 67 Duntov x2
66 bowtie x 2
71 LT1 TF
90 ZR1 McCelland
03 Anniverary
06 Z06- Top
