Re: CE stamped blocks numbers, do they identify the HP?
GM used a cast iron timing gear with nylon teeth cast on it. Teeth would break or the whole thing would separate. There were a lot of trashed engines because of that timing gear. I took it out of my 70 LT-1 & installed a cast iron toothed one.
