1965 corvette coupe dash rail color - NCRS Discussion Boards
  • John S.
    • January 1, 1998
    • 81
    What color is the bar that holds the vin tag and the trim tags on a 1965 corvette coupe. Is it primer or body color or black?
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 1965 corvette coupe dash rail color
    JOHN,
    Typically it is black. Not uncommon to see a portion on the ends green phosphate primer. The task was to only black out what the passenger would see. Some got more than other cars.
    • Keith B.
      • March 7, 2008
      • 928
      St Louis body's are typically blacked out in the bird cage area of the vin and trim tag. A.O. Smith bodies are typically still the green zinc chromate color with body color over spray on it
      • Gene M.
        • April 1, 1985
        • 4232
        Keith,
        Interesting you comment on AO Smith my findings show inconclusive. My three AO Smiths and each a bit different. Very early 67 black/white interior is very light black only on face side. The rest of the channel looks bare steel with light rusting. I would expect to see green. Late 67 teal interior the whole thing is green zinc chromate color with just a bit of silver body color on far right end. Blue/blue 65 the channel is only body color on right end to about the center of glove box, the rest is primer and then farther left it is some green zinc chromate color.
        • Keith B.
          • March 7, 2008
          • 928
          Gene I'm sure it mostly has to do how the sprayer felt that day and if he wanted to reach in there.
          • James W.
            • December 1, 1990
            • 2640
            Attached are a couple of pictures of the trim/VIN under dash bar from a St. Louis built, unrestored, Bowtie/Duntov awarded, 26,xxx mile '65 396 coupe. As you can see it hs the green primer on the bottom surface and blackout on the horizontal surface with a small amount of Glenn Green body color on the outer right side. Regards,
            James West
