Distributor, who has machine & does good setup? Prefer the So cal area. - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    Re: Distributor, who has machine & does good setup? Prefer the So cal area.
    Ignition Engineering in Anaheim. Did a quick turn around for me. Good with pertronix as well. http://www.distributorcurvingandrebuilds.com/
    • Domenic T.
      • January 29, 2010
      • 2452
      Larry,
      Thanks for the info.
      DOM
      • Joe C.
        • August 31, 1999
        • 4598
        #18
        Originally posted by William Ford (50517)
        Joe,
        Is it bad for the engine to check total advance by revving to where max advance comes in with no load on engine? Max advance on my '67 L79 doesn't come all in till 5100 with stock advance curve.
        A lot of people think that it's bad. My father did, too.
        But it should be perfectly OK to do so if the engine is in good condition. Including valve springs so you don't float the valves.
        If you can do it in gear, then you can do it in neutral.
        • William F.
          • June 9, 2009
          • 1354
          #19
          But no load in neutral
