Posted this in another thread, but wanted to start a new one. David Liukkonen has shared his thoughts, but was wondering what some other members thought? This 4657 top section has the characteristics of a later 40083 with the 2 gussets, but it is dated August 1962. Has anyone seen a 4657 top section like this? How would it judge? It is not what we typically think a 4657 top section should look like. Thanks.
Odd 4657 fuel pump for 1963?
Re: Odd 4657 fuel pump for 1963?
Also, I see that the font size of the 4657 stamp on the flange is larger than what I have read on this board previously. If I recall correctly early pumps have smaller font size and later pumps have larger font size. This pump is early with large fonts.- Top
Has anyone seen a 4657 fuel pump top section like this one? I have not, so it may just be common or possibly rare? No frog pads, 2 gussets, circular vs oval shape of area that the AC is molded into, large part # stamped into the flange yet early dated pump??? Since the pump top section is dated August 1962, does this not change what we typically believe the production 4657 should look like? Or could this be a pump for 1963 with L84 or L76? I doubt this because it has the same part #, 4657.Curious too, does the top section of the fuel pump have characteristics that make suitable for different types of engines/hsp or is it really just a part the is applicable to all engines/hsp? If there is no difference, than maybe the answer is that there were several molds used by the manufacturer and this is just an unusual 4657?How would this top section judge on a 1963 vette?- Top
Harry, thank you very much for the reply. This one seems to be stumping everyone... Anyone else seen a 4657 like this one? I guess if this exists it has to be correct for a 1963 corvette application.- Top
John D., thanks for replying. Are all top sections on these pumps, no matter the different visual characteristics, set up the same. In other words, does the top section differ for SHP engines versus base engines? If there is no difference, then perhaps some top sections were simply made with different molds, like this one? Not sure what else explains the differences we see on this pump. Thanks- Top
To answer the question of "How would it judge?" I would expect a 20% deduct for the Configuration element in the originallity collumn. It falls into the nontypical bucket.
Remember these pumps are made up of 3 pieces and can be assembled from many combinations of parts. The "4657" is just a stamp that could have been there originally or maybe added later by workbench elves....
The sad part of this deal is the JG was changed in the last revision to describe a 4657 pump I've never seen either. I questioned our fearless 63/4 team leader and he told me my question was "under review" but haven't heard from him for a few months on the outcome.
Maybe others should also inquire...
tc- Top
Tracy, thanks for the reply! Why the deduct on the configuration if it is dated August 1962? What is strange, at least to me, is it looks like a 40083 which is a later pump. Does not appear as though the workbench elves were experimenting with this one. Thanks again for your comments.- Top
Could it be possible the pump is stamped incorrectly and should be 40083, that would be logical except the date.- Top
inlet and outlet configuration are different between 4657 and 40083Bill Clupper #618- Top
Because it's not typical factory production. And, because it would be a bit difficult for judges to see the August 1962 dating.Tracy, thanks for the reply! Why the deduct on the configuration if it is dated August 1962? What is strange, at least to me, is it looks like a 40083 which is a later pump. Does not appear as though the workbench elves were experimenting with this one. Thanks again for your comments.
Fwiw, I have been looking at 4656 fuel pumps for 40 years, (the forerunner to the 4657, used 58-62) and have never seen that kind of a top on those.- Top
Bob, here is the photo you requested.Attached Files- Top
for a reply, to see if he thinks it would pass judging.
