I got in a 75 diff today that is pretty much junk. Before I part it I figured I would post some pictures you those of you who will be looking at used 63-79 iron diffs and may not be sure what to look for. This one came out of a beat up car and it's not hard to see this diff was making some noise............................................. .................................................. .................................................. .................................................. .................................................. ..............
.................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .............................................When checking a diff and you get past the numbers, look at the axles and the seal area. There should be an 1/8" boss in front of the seal. The axles should not be touching the housing. This one has axles worn down past the snap ring groove, both sides, they hit the housing machining it. The 1/8 boss is gone, the U-bolt cut into the ears, and the shields were distorted on the axles. This is pretty bad and I don't even know if the posi case is any good. I'll probably just drop it all in the scrape iron drum for about $2.
