The nut of this post is to ask: does anyone make a "better" repro? But here is why I'm asking.
What I have are Whittek #20s which are likely original but have been replated with a yellow dichromate finish and with stripped screws. I bought a pair of repros from Paragon. The problem I have is that it will take near screw stripping force to get the strap which is attacged to/pushed by the screw to feed through the slot, up and over. If I do this after I feed the loose end through and bend it back then is will only get harder. If I do in in advance then I use up most of my adjusting length just to get it "over the hump." In comparing these to my "originals" what I see is that the repro brackets use thicker material and the turned up sides (gussets) are wider making them more rigid. But more importantly, the originals appear to be "slit/sheared" at the ends of the slot on the side of the slot just under where the screw comes through. Without taking it appart I can't tell for sure but I think this appearance is the result of a die bend on the back side of the slot to create the clearance to make them work.
I'm fairly sure that Corvette Central sells the same product as Paragon. But I don't know about Long Island or Dr. Rebuild or others. Does anyone know?
