T-top bushings on 1970 - NCRS Discussion Boards
  • D S.
    • March 1, 2005
    • 1551
  • Michael F.
    • 745
    Re: T-top bushings on 1970
    pry them out and pop new ones in is the way i remember from back in the day
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
      Michael and Scott------
      Yes, that's how it's done. The nylon bushings simply pry out. New ones snap right in. The bushings are the same for both coupes and convertibles.
      The bushings, GM #3977779, are discontinued but I believe they are available in reproduction.
      • D S.
        • March 1, 2005
        • 1551
        Thanks Michael and Joe.
          • 3415
          Hi Scott,
          The AIM indicates that the 'paddles', as that part of the latch is referred to, should be set so that a 13-16 lb load is required to release them.
          I've never tried to measure the effort required for the locks on my 71, but I'd describe it as enough pressure being needed so that I can feel the rubber bumper in the adjustable 'peg' is being compressed as I close the latch. The 'paddle' pops into place.
          I'm sure there is a device to measure the load but I don't know what it is.
            • 15573
            This or any other hand-held scale will work, if you are so inclined.:
            http://www.basspro.com/Bass-Pro-Shop...product/13327/
            I can see Team Leaders using one for PV in the near future now that the issue has been raised.
