Enough..time to pull engine. - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    #31
    Re: Enough..time to pull engine.
    If you have any desire to have the car judged, then you can buy a junk 327 block with the right casting number and cast date, build it up to look as original.
    Hell......you can even dummy-up your engine block to look as original, too. All you need is some Epoxy and some iron filings.
    Otherwise, much easier and cheaper to buy a crate engine and drive-on. With a full warranty.
    If you want to build a 500+ HP 350 that will run on 92-93 octane, then send me an e-mail (not a PM) through this website and I will advise you.
