Back in the 60's and 70's it was a big deal. GM also had their version that was in every crate with a block. You would also think that they would also put a can of paint in the crate, but NO.
It was to be added to all the warranty engines. GM called it " GM engine oil supplement ". Other thick products that were most likely out of the same vat were Motor Honey, STP, GM engine oil supplement, and so on, in pint cans.
You could buy it at most oil suppliers by the gallon for $3.50, they called it VI ( viscosity improver ).
Customers requested it to be added to engine oil changes, manual transmissions, and open rear ends.
GM thought enough about it to put it in with crate engines.
There was a screw driver test advertised, a straight slot screw driver tip was dipped in motor oil and you could hold it by the tip, then dipped in STP and it would slide out of your finger tips.
I still use it on bearings during assembly because it's clear and you can see anything that shouldn't be on the bearing. Then I mix the rest with the engine oil. There are some racing oils that pass the screw driver tip test.
Dom
Dom
