Thanks to Duke Williams, I have Finally gotten to the bottom of why my full restoration 1964 convertible 327/365 SP Hi Perf engine with 4,500 miles has AlwaysThen, I stumbled onto the magic problem/solution in this post between Duke and another member that I previously mentioned!This correct orientation allowed me to get more initial timing advance since the VAC can was no longer hitting the intake manifold.
Duke saw my post on my fuel pump issue and we began communicating about this heat issue. He coached me through removing and reinstalling my distributor. He also walked me through many procedures such as confirming my 236-16 VAC can was performing up to specs and confirming the 2" rule he talks about in his San Diego presentation. We established baseline specs on my engine's "current" settings BEFORE we altered anything. I believe at the time my engine was only producing about 13" of vacuum which seemed low. Then he guided me through shimming my distributor drive gear up to specs to reduce spark chatter, installing lighter distributor advance springs (I now have "gold" springs/Mr. Gasket #928G advance curve kit) and completely dialing in my timing advance map curve. I think my initial timing is now 15* and I know my engine is producing more vacuum than before. The Dwell is set at 30* I think my new baseline is as follows but I may have some facts incorrect
