How Many Capacitors are at the back of the dash for radio suppresion on the back of cluster ? Does anyone have a pic of location? I know one for each turn indicator and one for ammeter. Is there another by ign. switch. Pics would be greatly appreciated. Thx Tom
66 Dash Radio Capacitors
Re: 66 Dash Radio Capacitors
If you have an AIM, look under U69 A4 for locations. There are a total of 4 capacitors behind/under the dash.- Top
just as a start, until someone gets you a better photo or illustration, here is a shot of page U69 A5 of the 1965 AIM.
I imagine that the 66 page shows the same illustration.
Three capacitors attached to the back of the cluster, one on the ammeter, one on the ignition switch and one on upper right side next to tach.
- Top
Nope - the cluster turn indicators don't get any capacitors - that chore is handled by the capacitor that installs over the terminals on the turn signal flasher. The only lamp at the top of the cluster that gets a capacitor with a crimp-on splice connector is the "Brake" warning light. See your Assembly Manual, section U69, sheet A5, item #6.- Top
67 Dash photo......Same as 66. 2 caps shown......- Top
They're all shown on one sheet in the U69 section of your Assembly Manual.
RadioCapacitors.jpg- Top
- Top
The "top" one has the push-pin connector that goes on the "Brake" warning light wire; looks like the photo below.
CapacitorPkBrkLt.jpg- Top
