I need to replace the camshaft on my stock L46 due to three exhaust lobes showing excessive wear. The stock cam (3896962) is still available, but I wanted to ask the more experienced hands if there are any other recommendations.
Engine Specs: Stock L46
Cylinder heads: 3927186 cylinder heads - have been shaved 0.005" as machine shop trued them to 64ccs.
Carburetor: 7029207 quadrajet.
Pistons: Stock L46 domed pistons
Exhaust: Stock ramhorn manifolds, stock 2" dual exhaust
Distributor: 1111491 TI distributor
Transmission: Muncie M20
Rear Gears: 3.36:1.
Driving wants/needs: No track, very much a cruising car that I like to take off the line sharply every now an then.
I do like a bit of rumpity in a camshaft. I would not describe the stock 962 as rumpity at all, very mild in my opinion.
I am concerned (may or may not be warranted) that the shaving of the heads just increased my compression, and I did have some detonation issues running on 93 octane (no ethanol) before tear down.
I would like to hear your opinions. If you have a specific grind recommendation, I'd love to hear about it as well.
Rear Gears: 3.36:1.
I do like a bit of rumpity in a camshaft. I would not describe the stock 962 as rumpity at all, very mild in my opinion.I am concerned (may or may not be warranted) that the shaving of the heads just increased my compression, and I did have some detonation issues running on 93 octane (no ethanol) before tear down.
