Where to find L designations as in L71 etc. - NCRS Discussion Boards
  • Domenic T.
    • January 29, 2010
    • 2452
    I was told once but forgot where to look. I get lost when reading posts and need to know which option one is talking about when using the L code. I can keep up with 300/327 or 435/427 and so on, but need a place to look to find out which engine I am reading about?
    Dom
  • Keith B.
    • March 7, 2008
    • 928
    Re: Where to find L designations as in L71 etc.
    Corvette Black Book is a good start
    • Don H.
      Moderator
      • June 16, 2009
      • 2236
      L is part of the RPO codes that you find in the Corvette Specs book or the Black Book such as A01 for tinted windows, C60 for AC, J50 Pwr brakes, K66 TI, L88 (you know what that is) M22, rock crusher, N14 pipes, yada, yada yada.
      Since all the info known in the world is at your fingertips with google, you can just google for instance
      "1967 corvette rpo codes" and one of the first responses you see is this
      that lists all the rpos, the color codes, interior codes, etc
      pps, terry, you should open your mind to pre-1968 corvettes. They really are the only true corvettes.....
        • 15610
        The absolute best source for summary information on vintage Corvettes are the two NCRS Specification Guides written by John Amgwert that are available exclusively from NCRS.
        My ten plus year old copies are getting so dog-eared from use, I'll probably have to buy new ones in the next couple of years.
        • Larry E.
          • 1652
          FWIW: I found this site to be helpful: Larry
          Larry
          LT1 in a 1LE -- One of 134
            • 15573
            Duke,
            You might want to consider new ones (Pocket Spec Guides) because we have updated them in the last 10 years. If I were home I would tell you the exact date, but Eric Mortimer corrected some early C3 mistakes (I know that may not matter to you). I don't know what other corrections there were (You know my focus) and some additional information was added.
            • Roy S.
              Past National Judging Chairman & Concours Team ******
              • July 31, 1979
              • 1022
              Duke,
              I know my focus is best at 15 feet
              • Domenic T.
                • January 29, 2010
                • 2452
                Thanks guys,
                Which book would be user friendly, (fast) so when reading a post, the code could be found in a reasonable amount of time? Or is it up to me to make my own lists using the book as a guide?
                Dom
                • Keith B.
                  • March 7, 2008
                  • 928
                  Originally posted by Domenic Tallarita (51287)
                  Thanks guys,
                  Dom
                  I use the Corvette black daily when using my forums or looking at cars for sale. Even though I have most stuff memorized I still need to look it up. I also use the NCRS pocket guide. The one I have is only for 53-67. So you can't use it for every year. But it has all the major numbers of all the drive line parts which the black book does not.
                    The NCRS Pocket Spec Guides were most recently revised in Spring, 2011 (both the Fifth Edition 1953-1967 and the Fourth Edition 1968-1982).
                      • 15610
                      You need some magic glasses like I have, Roy. I can see everything from hydrogen molecules to galaxies 14 billion light years away.
