Re: melling oil pump correct spring
As long as that modified pickup has the screen correctly located in the pan, I see no reason not to use it and the pump if it passes inspection, or you could buy a correct OE replacement pickup and install it if you wish.
The correct OE spring for your application is 3848911 according to my '77 P&A catalog with a note that is has 21 coils with a white stripe, but no free length or wire diameter.
The 40-45 psi spring is 3814903, 21 coils, 2 7/32" free length.
I'm sure those two springs are long gone, but maybe the OE numbers can be used to find a correct aftermarket spring.
If the maximum hot oil pressure previously was in the range of 55-60 psi on the gage, then whatever spring is installed is providing the OE spec oil pressure.
