Hi. My Head's read 3748770 x58 on side with the triangle on each end, (230 horse) the Nolan Adam's book show's several instance's with this but the judging book show's a different end marking. I had a 30 point deduct at a recent Regional. Were they wrong? Thank you.
58 Heads
Re: 58 Heads
Brad-------
Do the heads have accessory bolt holes on the end? Are the heads Tonawanda-cast or Saginaw-cast?In Appreciation of John Hinckley- Top
Re: 58 Heads
The correct heads will have a smooth or machined surface on the end markings. A shot of my 58 heads
PB101561.jpg1958, 283/245, White/red - Top Flight, October 2016
2007 Z06, Lemans Blue
Newsletter Editor, Delaware Valley Chapter- Top
Re: 58 Heads
Brad------
Under the valve cover (where the casting number and dates are found) is there anywhere to be seen a large "T"?In Appreciation of John Hinckley- Top
Re: 58 Heads
"Correct"......??
I can't say for sure as I am not a judge nor have I had my heads judged, but from what I know and have learned these are the right heads for the engine. I would not expect any deducts on my heads when judging time comes. March 58 car, late Jan 58 heads, but casting dates are not visible during judging as you are aware.
Tom1958, 283/245, White/red - Top Flight, October 2016
Re: 58 Heads
A two digit year, such as "57" on your heads, indicates they came from Tonawanda, never a source for small block Corvette engines. Some Tonawanda heads (notably '57, but possibly others) have end symbols which are detectably different from those on Flint heads.- Top
Re: 58 Heads
Brad -
Those are Tonawanda heads, and the raised symbols on the end of the heads will have an as-cast surface; the end symbols on Flint heads will have a smooth machined surface.- Top
