Purchased a look alike radio from Antique Auto Radio in Florida. Want to add Bluetooth via the RCA plugs in the receiver. The harness that plugs into the receiver has 3 wires Grey, Yellow and Black. Black is the ground but which do I tap for power?
Radio 12v wire
Re: Radio 12v wire
Dave,
Do you have a voltmeter? You could find out quickly if you do. How about a schematic? It should tell you. I hear you can get a voltmeter at Harbor Freight for $5.00 or so. Doc Rebuild has the best schematics that I've seen.
Joe- Top
Re: Radio 12v wire
Don't mess with the two black ground wires in the center cavity of the radio connector - that circuit grounds EVERYTHING IN THE CAR from the firewall rearward, on that one wire, to the bottom of the lower instrument panel brace.- Top
