Re: Ever heard of using " Hard Blok" to repair a severe crack cam tunnel in a 427?
Thanks to all for the comments. Here was my issue. This is an original car that I've owned 38 years that did not have an original motor. I knew both previous owners. I purchased a "good engine" bored .060 over from a classic engine re-saler that had 'been manafluxed', but apparently not water pressure tested. When I received the engine it had a scored piston wall and had to be bored to .070 over and a sleeve inserted into the scored wall. This engine was built and the car assembled to NCRS standards. Two weeks ago during a first start test, the radiator fill was not successful. Intake manifold removal showed the water leaking from the water jacket next to the second cam bearing.
The engine re-saler said it could be 'hard blocked'. After researching the company web site, it states it is for structural strengthening in race cars; therefore I contacted the company and was told "No" it was not designed for my repair.
