I just started having an issue with my 70 L-46 this week. It doesn't want to pull past 4500rpm. I also have the Lectric Limited pointless ignition. I'm going to try another coil this week. If that doesn't fix it, I'm going to re-install the points and see where that gets me.
70 L46 won't rev
Re: 72 LT1 Issue
The fuel bowls may be full of shellac from sitting. That will reduce the volume of fuel available causing the engine to max out on rpm's. Once I cleaned out the bowls my 70 LT-1 went to 6500 rpm just like it should.I just started having an issue with my 70 L-46 this week. It doesn't want to pull past 4500rpm. I also have the Lectric Limited pointless ignition. I'm going to try another coil this week. If that doesn't fix it, I'm going to re-install the points and see where that gets me.- Top
Re: 72 LT1 Issue
My car never really sits (the OP's may have). I just drove 1200 miles (roundtrip) for the New England Regional. The quadrajet is freshly overhauled as well. I'm fairly certain it's an ignition issue. Which item....well, that's another story.- Top
Re: 72 LT1 Issue
Mike,I just started having an issue with my 70 L-46 this week. It doesn't want to pull past 4500rpm. I also have the Lectric Limited pointless ignition. I'm going to try another coil this week. If that doesn't fix it, I'm going to re-install the points and see where that gets me.
When is the last time the sparks plugs were cleaned and the spark plug wires checked for resistance..- Top
Re: 72 LT1 Issue
Two days ago, as part of the trouble shooting process. The plugs have around 4000 miles on them (all very close in color/condition). The wires ohmed out from 10k (shortest) to 17k (longest).- Top
Re: 72 LT1 Issue
The wires (Lectric Limited) are about 2 years old.
I just got off of the phone with Lectric Limited Tech Support. Was told that a high performance ignition coil with very low resistance (under 1.2ohms) have been known to cause problems with their breakerless ignition. I'll have to measure my coils resistance tonight.- Top
Re: 72 LT1 Issue
Mike,
Start the engine in the dark before you take anything apart to see if you get a light show going on, you will then get a idea where to start.
Keep in mind after you get the resistance of your ignition coil call M&H fabricators as they are the company that makes the Breakerless SE,. Lectric limited is a retailer of this ignition upgrade, my thought is that it will work or not work but I could be incorrect.- Top
Re: 72 LT1 Issue
Have already done this, all ignition shielding has been removed (except boomerang shielding), no light show.- Top
Re: 72 LT1 Issue
Mike,
If the engine just goes flat like there is no fuel then check the pump pressure to eliminate that. I would be surprised if the breakerless is at cause, call M&H and explain the condition and see what they say first.- Top
Re: 72 LT1 Issue
The OE type RFI wires should measure no more than 5000 ohms per foot of wire length, and the front four on a SB are about three feet long.
Duke- Top
Re: 72 LT1 Issue
Update - Changed coils and that seemed to fix the problem for the 20 mile test run. The "offending" coil was the BR 270 repro (1.3 ohms), approximately 1 year old. I stuck in a 20 year old coil (1.8ohms)that came with the car and it ran great. I'll drive it for a few weeks and see what happens.
Thanks for the help.- Top
