Since my last disastrous oil change, I have again gone back to considering a conversion to a spin on filter.
As best I can tell, there are two different basic designs;
1) I have in my stock of parts a kit I bought a long time ago during another one of my weak moments. It is made by Cal Customs and is designed to be used with spin on filters that have a built in PRV (of which I have two in stock; Wix #51515). As such, to mount the adapter you must remove the PRV plate. The adapter then mounts in place of the PRV using the two original bolt holes that held the PRV. The filter appears smaller than an original PF-35, both in diameter and length. I assume both the PF-35 and original canister hold a full quart.
2) The current design I see offered by CC (there p/no. #301220) appears to retain the original PRV and O-Ring gasket, bolting through the adapter and PRV with a gasket in between.
My questions are; has anyone ever installed either type kit, and what was your experience with them? Also, in general, will the filter with the built in PRV be adequate both in volume and pressure relief for use on my 63 L-76 engine which, of course, has the higher pressure oil pump?
Interested in hearing your comments before I commit myself to using what I have, buying new parts, or jobing out my oil changes.
Stu Fox
Stu Fox
