The ignition buzzer in my high-mileage '72 will sometimes buzz when I open the door, even after the key is removed. In the past when it has done that, re-inserting the key and wiggling it would always stop the buzzer. This morning when I got to work, it would just NOT go off. Fortunately, I have a battery cut-off switch, so I disconnected it so it wouldn't buzz all day and run down the battery. I'm not familiar with how the buzzer is switched. Is it likely that my ignition switch is worn out, or maybe just needs cleaning? Has anyone had a similar problem?
1972 ignition buzzer
Tags: None
Re: 1972 ignition buzzer
Tim, There is a plastic switch that commonly breaks from age it surely sounds like the problem, I have a tilt and tele. column and replaced this switch in my 72. both the tilt and fixed steering column have the same problems with switch.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Corvette Central part number 593064 for this switch. I would get it while it is available as it has been unavailable in the recent past and appears to now be in stock again. P.S. This part number is for tilt-tele. I don't think CC has the switch for non tele but check with them.- Top
Russ, I believe that Corvette steering makes the switch for the tilt and tele. they started making them about 3 or 4 years ago. Not sure if that's who you are referring to.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Thanks to all for their responses. OK, here's a dumb question: Where exactly is the switch, and how do I get to it?- Top
The Chevrolet Chassis Overhaul Manual for your year has a step-by-step. Jim Shea posted a image from there. You may also need the appropriate year AIM with the ignition lock installation instructions in order to re-install the lock properly.Terry- Top
Thanks Jim. I do have the standard column, and that's exactly what I needed. Terry, I do have the Chassis manual, but since it's not Corvette-specific, I didn't think it would be much help. (Guess I was wrong!) And I do have the AIM, but wasn't able to locate the switch. Thanks again to all who replied!- Top
Timothy while you are awaiting for your new switch if your 1972 is just like my 1970 you can easily disconnect electrical power to the buzzer. It is located to the left of the brake master cylinder and you can just pull the plastic housed terminal from the relay. I did this to my 1970 many years ago to silence the buzzer.- Top
A long shot, but if you have a cooperative parts man, have him do a dealer search for the old part #. I found a Buick dealer in the middle of nowhere (kinda like where I live) that had a N.O.S. one in the Saginaw bag for my tilt column. Charged me all of $7.20! I bought a whole bunch of discontinued steering column parts this way. I basically bought any part that I thought could wear out! I'm guessing this MAY be a common part to several GM car lines. I'm sure Jim Shea would be able to answer that.
1973 LS-4 454 coupe owned 24 years
1996 LT-4 Collector Edition coupe owned 13 months
Sierra Nevada Torpedo IPA-currently on tap!- Top
Tim------
The part you need was GM #7804414. GM discontinued this switch some time ago but I'll never figure out why. It has extremely wide application among MANY GM cars for about 20 model years. Plus, it's an often-needed part. It is reproduced. I don't know what the quality of the reproductions is but they are out there.In Appreciation of John Hinckley- Top
