57 timing tab - NCRS Discussion Boards
57 timing tab
  • Greg K.
    • September 30, 1985
    • 32
    57 timing tab
    I've found some timing chain covers with different timing tabs. Some have A-O and others have A-O-R for the advance-retard readings. Does anyone know if the 57 came with either or if it was truly one way or the other. Would appreciate some clarification.
  • Wayne L.
    • September 30, 1981
    • 233
    Re: 57 timing tab
    I believe A-0 is correct for the 1957 timing tab. The A-0-R tab started being used possibly in 1964??????
    • David L.
      • July 31, 1980
      • 3310
      Re: 57 timing tab
      Enclosed are 2 photos of my 55-61 timing cover (in very poor condition) as well as a sketch of the timing cover tabs which is based on research over the last 30+ years.
      Dave
      • David L.
        • July 31, 1980
        • 3310
        Re: 57 timing tab
        Here ia a photo of a timing cover from my 1966 Corvette w/base 327. The 1967 Corvette w/base 327 cover is the same except there were date codes stamped on the cover. In years past I have had these covers stamped "12 66" and "1 67". I believe that "early" 1966 models had the small tab like the Late 1964 & 1965 models.
        Dave
        • Greg K.
          • 32
          Re: 57 timing tab
          Dave, I'm a little confused now. Your last photo shows the timing tab A-O-R on your 66, but your sketches show that should be an A-O.
          • Greg K.
            • 32
            Re: 57 timing tab
            Or are you saying t=he 66 has A-O-R but with a notched tab vs a ramp?
            • David L.
              • July 31, 1980
              • 3310
              Re: 57 timing tab
              Greg,
              My sketches are for 55-61, 62-E64, and L64-65 timing tabs, no sketch for the 66-67 tab.
              Dave
              • David L.
                • July 31, 1980
                • 3310
                Re: 57 timing tab
                Greg,
                Here is a scan from my research on timing cover tabs. The sketch of the 66-67 tab is on the lower left. The parts numbers listed are for service timing covers, not necessarily the same as production timing covers.
                Dave
                • Greg K.
                  • 32
                  Re: 57 timing tab
                  This has been extremely helpful Dave. And makes more sense to me too. Thanks so much.
