Looking to obtain a Vehicle Appraisal Valuation on a '74 Corvette located in CT. Any thoughts and/or recommendations? Thanks, Ray
Vehicle Appraisal Valuations
Tags: None
Re: Vehicle Appraisal Valuations
The reason for the appraisal is to determine a value for the purposes of a divorce settlement.- Top
It's $1 then, right?Vice-Chairman (West), Michigan Chapter NCRS
I assume that the car was probably insured, for an "agreed" value. If yes, going with the agreed insured value would be hard to argue - it may or may not be in your favor but it will be a number that has been established some time ago and not prejudiced by other external influences. Essentially, it is probably a safe number to go with, right or wrong. Good luck.Ed- Top
Agree with Ed. Also, Hagerity has a very good Valuation Guide on their website that could be used. Hemming's also has a long list of Car Appraisers in just about every state. I could check for you if you want. Chuck Berge is also an excellent resource if you need a personal inspection and appraisal. He lives in Virginia and advertises in the Driveline. I would call him first if a personal inspection is needed/desired.
Larry- Top
That depends on whose name it's in!
You might try Terry Shaw at Automotive Legal Services from Dresher PA. I'm certain he can help you with your exact needs!
http://www.yelp.com/biz/automotive-l...rvices-dresher- Top
