As soon as the ratio lever moves to economy, it dies. Seems like a big vacuum leak, it will stay running at rpm's over 1200 or so, prior to ratio lever switching to lean it's fine . I have a spare running 320 unit, which it runs fine with, I have also isolated the problem to the plenum by installing my spare Fuel and air meter & new CSV and full plenum gasket. It has Q12 nozzles which I swapped with my S14's, it didn't die as quickly but would stall after idling at 1k for a few sec's. I shook the spider check valve and it rattled, it has a siphon valve which I bypassed, no change. I did a smoke test on the plenum, and got some seepage around each nozzle body, but no where else, so I replaced the nozzle gaskets, no change in operation. I'm open to ANY ideas, as I'm about out of them
, can any of you FI experts help please ? Thanks much. Lyle
