1965 Accelerator lever ground strap?? - NCRS Discussion Boards
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 831
    I am looking at page 418 in the 1965 AIM. I do not see a star washer at the accelerator lever for the ground strap. After witnessing several original cars and accelerator levers without star washers or witness marks from star washers I believe this to be true. Anyone else care to comment? Thanks, Joe
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 969
    Re: 1965 Accelerator lever ground strap??
    Joe. I know that Marco Hartner is helping put together the mechanical section for the new '65 JG. I won't speak for Marco, but you may want to get his insight. Best, Tony
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
    • James W.
      • December 1, 1990
      • 2640
      The '65 396 convertible that I restored and put through chapter, regional, and national flight judging this year was put back together without a star washer and no deductions were taken. The car never had a star washer to begin with, neither does my other '65 that has not been restored. Both cars are late build cars, one is 2209x (A.O. Smith) and 2216x (St. Louis) built.
      James West
      • Timothy B.
        • April 30, 1983
        • 5177
        The accelerator lever is plated so it does not need the star washer to bite like the painted frame.
        • Jimmy B.
          • July 31, 1980
          • 584
          my 65 #19371 sb 300 w/ac/auto had a star washer on the accel lever ground strap mount. Same owner since at least 1968 and possibly the original owner.
          • Page C.
            • February 1, 1979
            • 802
            Hi Joe,
            Looked at 3 unrestored 1965,s and none had a star washer or any evidence of ever having one. One is a early Dec 64, one late June and one mid July 65.
            • Wayne M.
              • March 1, 1980
              • 6414
              Originally posted by Page Campbell (2299)
              Hi Joe,
              Same here, Page. Both my unrestored '65s [Nov 6th L76 and Aug 2nd L78] show no marks that would indicate such a washer. Same with the lever I pulled off a 396 body in a junkyard in Spokane WA, in the early '90s.
              • F S.
                Infrequent User
                • January 1, 1981
                • 28
                Where does the other end of that ground strap connect to ?
                • Don H.
                  Moderator
                  • June 16, 2009
                  • 2236
                  Underneath the left rear intake manifold bolt directly under the lever. The same bolt is holding the left side plug wire support.
                  Leif
                  AIM U69 A4 shows the eyelet above the bracket, under the bolt head, no washer on either end.
                  • Leif A.
                    • August 31, 1997
                    • 3607
                    [ATTACH=CONFIG]56380[/ATTACH]
                    Don,
                    It appears that your strap at the intake manifold bolt is on top of shield support bracket...was that the case in '65? I know in '67 there was a star washer at the accelerator lever and the manifold end was under the shield support against the manifold.
                    Leif
                    • F S.
                      Infrequent User
                      • January 1, 1981
                      • 28
                      I am looking for some direction on the ground strap location for the door sill for a 65 convert., and for the motor mount location. Any help would be greatly appreciated. FRED
                      • Jim D.
                        • 2882
                        April build 1965 - no star washer and the ground strap is under the bracket. 1 owner car that had never been touched.
                        • Marco H.
                          • March 1, 2002
                          • 218
                          Joe,
                          As you stated, the AIM does not list a star washer at the accelerator lever ground strap. While some cars were built with them, many had none. For some reason, the current JGs (not just '65) are calling for a star washer. The new '65 edition JG should be corrected. As others mentioned, a star washer was used, when a ground connection was made into a painted surface such as the frame, core support and headlight motor brackets.
                          Hope this helps,
                          Marco
                            • 6940
                            I thiink the 63 JM also states the star washer should be there,But a few here have already stated that is should not be there. How ever the some Judges are still deducting for missing star washers.
                            • Dan H.
                              • July 31, 1977
                              • 1365
                              Ed, there's even a picture from the AIM in the JG that shows no star washer used there. Guess the Judges should learn what an AIM is and maybe look at some origianl cars?
                              Dan
                              1964 Red FI Coupe, DUNTOV '09
