It seems to be OK and accepted to lower engine C/R, cam, head gasket thickness, and timing. I see the engine as the heart of the car and think that it should be kept as it was engineered by GM. I know that fuel has changed and that is a big problem, but changing the C/R, timing, and other things makes it run like a station wagon! Seems that that is ok but if the paint job is not sloppy on the manifold or missing on the bell housing, it is not acceptable. If we improve on factory mistakes like paint runs, dullness, body lines, and let things rust like the exhaust, it is not OK?
I know, restore to original, and I respect that. So why is it OK to change the very reason some of us bought the vette?
When I change my timing to run pump gas I take a LARGE hit on HP. Yes it runs, but it does not perform. To each his own but I chose to keep the engine power as it was. My fault was that I have a hard time duplicating mistakes that were not supposed to be there in the first place. I don't think the workers were told to be sloppy around the weather stripping, shoot paint runs, bad finish and so on. What about the vette that came out straight and had no glue showing around the seals, better paint, and was actually like it was supposed to be? It would take a hit if judged.
Again I do respect the judging and do understand what NCRS means. Also I respect the fact that we restore it to our own standards.
Dom
Dom
