1968 Battery Disconnect - NCRS Discussion Boards
  • Mike W.
    • November 1, 1990
    • 71
    I'm having problems finding a battery disconnect switch that works because of clearance issues and cable length. This is a top post battery. I tried a blade type switch, but the cable would not reach the post on the switch. I looked at the type with the turning knob on top, but I feel like the cable would be in a bind because of the necessary twist to install the terminal on the post that would stick out horizontally. Has anyone had success with this issue?
  • Terry B.
    • August 31, 1999
    • 607
    Re: 1968 Battery Disconnect
    Mike,
    I use the knob turning type disconnect placing it on the negative side of the battery terminal and it works just fine on my '68.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Gene M.
      • April 1, 1985
      • 4232
      Originally posted by Terry Buchanan (32872)
      Mike,
      ditto here, Mike, I don't understand your issue, should fit no problem.
      • R N.
        • May 31, 2002
        • 640
        I used the blade type switch on my '70 - The switch can be reconfigured to suit the application. I had to do the same with the switch for my mid-years too.
        On the underside of the switch are two c/s screws, remove them and swap the ends of the switch - it may give you that little extra you need.......
        • Mike W.
          • November 1, 1990
          • 71
          Thanks Kurt I will try that
