I just obtained a correct set of 5 spoke wheels and center caps for my '96 CE. One of the Corvette parts vendors lists a rubber O-ring seal for these caps. My question is; did they come with these seals from the factory. Just curious...the judging manual doesn't specify. Thanks, Paul
'96 wheel center cap rubber O-ring seal?
Re: '96 wheel center cap rubber O-ring seal?
I bet I sold it new. Any idea who's it was ?? I may have a picture of it with the original owners !!Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
PM me the VIN if you like. I can see if I have anything on it !
Tom Hendricks
Hi Paul ! Just noticed my inbox here was full. I just cleaned it up. You can PM me your email and I will send you the records I have.Tom Hendricks
Paul------
The 1996 wheels did not use an o-ring seal for the center cap. However, the 1988-89 QA1, 17" wheels did use such a seal. These caps, GM #10055340 and about 150 bucks each GM list at the time they were discontinued, were among the most expensive caps ever used on a Corvette aluminum wheel. The o-ring seal was GM #10097592, also now discontinued.In Appreciation of John Hinckley- Top
