I dropped the body Sunday. I then spent most of Monday and Tuesday lining up the body to the mounting holes.
I just spent all day today trying, to no avail , to center the gas neck to the car ! It is to far forward and refuses to move rearward ! I did some research in the archives and found this :
John Hinckley (29964)
Join Date
December 1st, 1997Posts16,062
Re: Fuel Tank Install
Join Date
Also, duplicate the locally deformed areas in the weld seam flange where the straps pass by in the front and rear of the tank; I don't think the repro tanks have the seam flange bent at those four locations, and it makes attaching the straps and centering the filler neck in the body opening extremely difficult.
END QUOTE.
Well sure enough I have a replacement Quanta gas tank and while the flange in the four areas is bent , it is nowhere near the amount my original was . So while the solution seems obvious
my question is : How do I bend the flange to the correct amount without disturbing the weld seam ? It would be a small consolation to have it fit but then leak !!!
Once again counting on your expertise and past experiences.
Jim
END QUOTE.
Jim
