Deck lid has lifted - NCRS Discussion Boards
Deck lid has lifted
  • Greg C.
    • February 5, 2013
    • 29
    Deck lid has lifted
    Hi guys, I just recently had my 67 roadster painted and new weatherstrip installed. The back edge of the decklid is up quite a bit..will this settle or do I have to treat the W/S to soften it up?,Thanks
  • Joe R.
    • July 31, 1976
    • 4547
    Re: Deck lid has lifted
    Greg,
    The weatherstrip can be treated to soften it up. I use Silicone Spray very carefully to make sure I don't get it on anything that needs painting in the near future. Also, on the deck lid, pop the soft-top as it pulls up on the decklid. I usually place a large heavy weight on the decklid using towels to distribute the load and protect the surface. Leave the weight on the decklid for several days until the weatherstrip takes a set.
    If that doesn't work get out the shims and pull it down with the hinge.
    JR
    • Michael G.
      • January 1, 1997
      • 1251
      Who is the maker of the weatherstrip?
      • Greg C.
        • February 5, 2013
        • 29
        Hi..I got the whole W/S kit from Corvette Central,thanks
        • Tracy C.
          • July 31, 2003
          • 2739
          Greg,
          As a rule the new weatherstrip is more soft and supple that the old hardened originals. I would put a 1/32 nd shim between the hinge and deck lid at the the front bolts and see what you gain. Vary the thicknesses until you get it leveled out with the rear.
          tc
          • Greg C.
            • February 5, 2013
            • 29
            Thanks for your help guys..!
