Hooking up vac and engine compartment wiring on fresh restoration of 70 LS-5 w/PW. AIM and local cars I have been able to look at are either 72 models or 70 that did not have PW. My issue is the location and mounting of the PW relay and the temp switch relay. The 70 had just the temp relay, obviously, but the 2 screws mounting it are the same spacing as the PW relay and there are no other similar mounting in the area. Are the two relays mounted opposed on the same mounting screws? If so, which is to the right and which on the left of the mounting screws? Using the common mounting screws is the only logical way I have come up with. If I mount the temp relay with wires coming in from the left like the non-PW car had it, with PW relay to the right, PW relay almost touches the H/L vac switch mounted on the brake box. So, I reversed them and things will hook up, but I would like pics or confirmation: 1-they used the same mounting screws and 2-the orintation.
Any help is appreciated.
Mike
Mike
