I put the key in the ignition turn it to crank the engine over - all good - however when I turn / crasnk the vette over and switch the key back to off the starter still keeps on cranking until I loosen the battery terminal / cut the power off.
When I connect the terminal again the engine is dead unill I crank the engine again - just another thing it does not do this all the time - I have changed the ignition switch for new and had the starter checked out OK.
Help guys cheers Keith
