On a 65 4spd car rear tranny mount uses two big thick washers anyone know the diameter on these and thickness, thanks
C2 Rear tranny mount big thick washer?
Re: C2 Rear tranny mount big thick washer?
Jim -- need more info. Are you referring to those shown on '65 AIM UPC 6 sheet B6 ? The only flat (plain) washers shown are item 7, part # 3700338. The bolt goes through the bracket that attaches to the frame X-member, into the motor/trans mount assy, which, in turn bolts to the bottom of the trans tail housing. The exhaust pipe hanger bracket is in there somewhere as well.
If so, the two used ones that I have that came (loose) with a rear mount are 0.15" thick, 1.00" OD, and 0.46" ID. The bolt is 0.425" by 1.40" OL with an "M" head marking with 3 radial lines (if that helps to identify).- Top
Jim------
These are the GM #3700338 that Wayne mentioned. The spec I have on them is an ID= 0.46", OD= 1.38", and thickness= 0.18"
Reproductions are available from AMK Products.In Appreciation of John Hinckley- Top
