I need to know the length of the dipstick on a 1970 454 with AC. I know it is supposed to have a black top like the small blocks & there is a long & short tube & both were used on the 454 so were there 2 different lengths when the long & short tubes are used. Guide doesn't say what the lengths are.
1970 454 with ac dip stick question
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDETags: None- Top
Re: 1970 454 with ac dip stick question
Kenneth------
I don't think that there was a difference between C-60-equipped LS-5 and LS-5 not equipped with C-60. Some folks think so, I do not. However, there was a difference between early LS-5 and later. Early cars used a dipstick which was 17-13/32" from seat to "full" mark and 19" from seat to "add" mark. Later 1970 used a dipstick that was 22-11/16" from seat to "full" mark and 23-1/2" from seat to "add" mark.
I don't have the length of the early tube. However, the later tube had a developed length of 22-5/8" end-to-end.In Appreciation of John Hinckley- Top
THANKS JOE I didn't think so either. I have the early kind but the black plug is missing. My 70 454 with AC length is as you described. My VIN # is 7601Kenneth------
I don't have the length of the early tube. However, the later tube had a developed length of 22-5/8" end-to-end.65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
-Kenn
1970 LS-5
1970 350/300
1980 L-48
2004 LS-1- Top
THANKS I am sure mine is correct so I will buy the plug. Makes me wonder if some didn't have one. If it's not too much trouble could you measure yours & tell me what wording is on it? KEN65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
3 1970 cars...nice.
One of my favorite years.
I imagine they did come with a plug, but after 40 years those puppies likely just fell out. Not much holding them in.
The overall length is 24 7/8", from the tip to the...boss? The knob that fits into the tube to secure it.
From the tip it reads: ADD | | FULL, with the line near ADD being 13/16" from the tip and the line near FULL being 1 5/8" from the tip. There is no cross-hatching or holes (later sticks often have these features).
There is a slight twist starting at about 8" and running to 11", from the tip.
Hope it's helpful.
-Kenn
1970 LS-5
1970 350/300
1980 L-48
2004 LS-1- Top
3 1970 cars...nice.
Hope it's helpful.
Kenn------
Based on the dimensions you mentioned, this dipstick sounds like the 2nd design 1970 Corvette big block dipstick. This dipstick has a red plug.In Appreciation of John Hinckley- Top
THANKS KENN Believe mine is like yours. Wording is for sure. I will measure to see if it is the same length. My VIN is 7601 so you are right about being the same as yours. Black tip Red tip maybe I should get one of each.65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
