the screws that hold the side panels (where the air vents and fresh air pulls are) on the center vertical part of dash (where radio is mounted)........do these screws have a captured washer on them or is it just a plain trim screw without built in washer.. I believe they are #6 or #8 size....thanks.
console screws on 67 vette ??
Tags: None
- Top
Re: console screws on 67 vette ??
Mike.......if it's anything like the side panel screws used on my '63 and '66 is a phillips screw that appears to have a captured washer but is just large flat screw. Gosh, I hope that make sense.the screws that hold the side panels (where the air vents and fresh air pulls are) on the center vertical part of dash (where radio is mounted)........do these screws have a captured washer on them or is it just a plain trim screw without built in washer.. I believe they are #6 or #8 size....thanks.- Top
Like this on the trim.
Like this on the radio panel.- Top
both your replies are exactly what I wanted to know and the pictures Wayne tell it all....thanks, I had both types of trim screws but after 25+ years since taken apart I had forgotten...thanks again.Michael
70 Mulsanne Blue LT-1
03 Electron Blue Z06- Top
