66 - brake calipers - NCRS Discussion Boards
66 - brake calipers
  • Stephen L.
    • August 29, 2007
    • 205
    66 - brake calipers
    JG at p 167 says:
    Standard brake calipers
    Originals have a single pin on the top of the caliper that holds the brake pads in place. The front
    calipers have only one steel bleeder screw. The casting numbers for the 2 halves of both front
    calipers are #5465952 and#5465954 .
    But i can't find where it lists the casting numbers for each half of the rear caliper - does somebody know those numbers?
    thanks
  • Stephen L.
    • August 29, 2007
    • 205
    Re: 66 - brake calipers
    was just speaking to a vendor who says the correct numbers are 5465902 and 5465905 - do you all agree?
    • Jim S.
      • March 1, 1986
      • 1392
      Stephen,
      Yes , and you can find that info on page #185
      • Stephen L.
        • August 29, 2007
        • 205
        got it
        Thanks Jim
        • Wayne M.
          • March 1, 1980
          • 6414
          Late '65 rear calipers had a dab of orange paint and sometimes a bit of white / ivory. Here's the inboards (left and right) off 23564. I've seen others with this, as well.
          c
