1963 seat frame id lr-rh - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 799
    a few years ago I bought a pair of bare seat frames at Carlisle and iam not sure witch is the driver or passenger seat is there any way to tell ? also how do you remove the tracks to clean the old grease from them before I sandblast the frames. thank the help.
  • Harry S.
    • July 31, 2002
    • 5258
    Re: 1963 seat frame id lr-rh
    Bob, the LH and RH sides are the same for a 63. It's essentially impossible to remove the tracts. I've done two sets of 63 seats and they do not come apart.
    This is what I have done and it works well. Before you media blast them spray the grease with BRAKE CLEAN. I used five cans prior to the media blast and four cans after the media blast. This will remove the old grease and the residual media deposits after the blasting. Do not grease the tracts till after the burlap, foam and vinyl was re-installed. This way all that material stays grease free. Prior to installation in the car, work the tracts till you get a smooth slide.
    • Bob W.
      • December 1, 1977
      • 799
      Harry thank you for your reply. now I can sleep at night! I look and look at the frames and didn't know . what got me thinking is the seat covers say drivers bottom drivers back ect. I was thinking the same about cleaning the grease from the tracts, brake clean or 2+2 carb cleaner. so thanks for your help again. Bob
