I did some research for a question on the CF with respect to Rolling Model Changes (RMCs) made during the 1976 Corvette model year.
The 1976 Vette model year had many RMCs that are documented in my two 3 inch 1976 AIM binders. I ordered and purchased a new 1976 Vette. One of the earlier changes was to the rubber rear bumper cover. One RMC that I know occurred was a change to the CORVETTE rear name plate and bumper cover. The 1976 start of production plate was small and fit into a relief molded into the cover. The CORVETTE name plate was made larger and the cover was modified to be flat. My Vette arrived at the dealer in early May and the name plate was the larger one. This change was not documented in my AIM books. It only shows the later large script name plate and completely flat rear cover.
FYI, my Vette came with he "old style" A6 air conditioning compressor.
I did see a very late 1976 Vette and it had an overhead dome light (not in the rear view mirror).
I was able to obtain a two volume set of 1976 Corvette AIM manuals directly from Chevrolet Engineering. Whether they were up to date or the latest info, I do not know. They did have many sheets labeled as "Rolling Model Change."
I do not know if AIM books available from other sources have this 'Rolling Model Change" info or not.
These are the various build catagories with "Rolling Model Change" on the various AIM sheets:
Storage compartment behind the seats.
Windshield moldings
Sun visors
R4 AC compressor
AC lines
Roof panels and Roof panel locks
Coat hook
Rear window trim panel
Roof panel stowage strap
Horns
Underhood wiring for the R4 compressor
Dome light
Elimination of the rear compartment lamp
Radiator mounting and support seals
Radiator fan shroud
Rear bumper bar
Tail lamp mounting panel
Several sheets have "Waiting Layout Approval" on them. I do not know if that tied into Rolling Model Changes or not.
Rolling Model Changes were supposed to save General Motors considerable money. By "Pulling Ahead" changes instead of making them a model year change was supposed to reduce obsolesence because the assembly plant was supposed to work the new parts into the system as old parts ran out. I doubt that it really worked that well however.
Jim
Windshield moldings
Sun visors
R4 AC compressor
AC lines
Coat hook
Horns
Dome light
Radiator fan shroud
Rear bumper bar
Jim
