On the drivers side inner fender with the 4 plastic clips. One by the hood support(BB), two close to the alternator and the forth by the voltage regulator. Are the two by the alternator the same on a SB as BB seeing how the alternator is in a different location. The car had the front clip replaced so I am trying to get all the correct locations. We also have a un-hit 67 SB car to compare. This is for a 427 car
67 wiring harness clips SB vs BB
Re: 67 wiring harness clips SB vs BB
Keith,
Yes, they are. Page 153 of the '67 TIM&JG states "The left headlight harness lead has a tan wire connected to the bottom of the brake differential pressure switch and is routed over the top of the left inner fender skirt and held in place with three push-in wire ties...etc, etc" No call out for differentiation between SB and BB.Leif
Top Flight 2017 Lone Star Regional- Top
