TI box on 70 - NCRS Discussion Boards
TI box on 70
    • 3415
    Re: TI box on 70
    Hi Peter,
    Yes, that's the location of the dimples I see too.
    Interesting question about mounting orientation!?!
    • Paul O.
      • August 31, 1990
      • 1716
      Re: TI box on 70
      Over the years of looking at many TI cars the position of the Amplifier was not always consistent. It could be higher, Lower, to the left or right of the car you looked at 15 minutes earlier. So the only statement that works it was installed to the left side of the radiator core support to the forward inner wheel well skirt. To the rear of the left headlight assemble with 3 bolts and nuts. Have seen most common bolt TR and the some Rockford with an un-thread section, Nuts had a built in star lock washer. Silver plated finish.
        • 15573
        #18
        Re: TI box on 70
        Originally posted by Michael Funk (22104)
        Joe which one do you think is better for weather protection? thanks for the great info.
        Ah, if one only had the latest 1968-68 TIM&JG one would find a Service Bulletin that describes water intrusion into the first design TI Amplifier. That is the reason for the pig-tail connector in the second design.
        We write these books and no one reads them.
        • Michael F.
          • 745
          #19
          Re: TI box on 70
          Terry, I am hoping I receive one under the tree next week
          Michael
          70 Mulsanne Blue LT-1
          03 Electron Blue Z06
            • 15573
            #20
            Re: TI box on 70
            The TSB (Technical Service Bulletin) is int he 1968-69 TIM&JG, since it was published in that time frame.
            • Wayne M.
              • March 1, 1980
              • 6414
              #21
              Re: TI box on 70
              Terry -- here's the first TSB related to moisture getting into the TI amp box, with an earlier Service News warning (below). Prior to the pigtail era, although the issue was probably the same, or easier R & R,
              c
              • Joe R.
                • May 31, 2006
                • 1822
                #22
                Re: TI box on 70
                Hi Wayne,
                That's some good info! Can you please tell me what year(s) that Technical Service Bulletin would apply to?
                Thanks!!!
                Joe
                • Michael F.
                  • 745
                  #23
                  Re: TI box on 70
                  Wayne,
                  agree with Joe, very useful info. can you either scan or pm me a copy of the TSB, I would like to follow the TSB and add the silicone grease when I install the amp...thanks.
                  Mike
                  Michael
                    • 15573
                    #24
                    Re: TI box on 70
                    Wayne
                    Those are exactly the items that are in the 1968-69 TIM&JG. That is why I wrote: "We write the books and no one reads them."
